Hi all,
Im trying to create my own Blogger template within FW Pro, following these instructions:
http://www.softpress.com/products/greatfeatures/blogger/
So far so good, I have uploaded my Blog and it works… all expect ALL the images are missing!!!
Step 9. Upload your site using the Upload command in the File menu. Note: This step is important—if your blog has any images they will need to be uploaded to the web for Blogger to see them.
When it says “images will need to be uploaded to the web” does this mean directly into the blogger site? If so where? Or will it reference them from the resources folder on my server, as currently they dont, all the images are replaced with small blue ? boxes!!!
Does the path need to be absolute or am I missing something?
Many thanks
Worm
