[Pro] creating email help
I’m trying to produce my first freeway email (based upon the template in 5.5) My problem is that if I view locally it’s fine but as soon as I try to view online the email shows up but without any images all html type is viewable but not gif type. Layers are off and CSS is on
Ami Im missing something obvious?
thanks
Ian
It sounds like you may have entered the web address incorrectly. If you uploaded to a folder on your server then you need to include that folder name in the web address. So, if you uploaded to a folder called email then the Web Address should look like this (replacing example.com with your actual web address):
http://www.example.com/email
Does that help? If not, send a link to the page online and we’ll let you know exactly what’s up.
thanks
Ian
Hi Ian,
The workflow for this action is quite specific so you may have
something slightly out of step.
It sounds like either the web address (in File/ Document Setup/ Upload
tab/ Web Address) is incorrect, the setting in the action (Use
absolute links) is set to preview the images locally or simply that
you haven’t uploaded your page yet to a public server.
Follow the steps in the video guide (below) and if you get stuck let
us know and we’ll dig deeper;
http://www.softpress.com/tour/new-in-freeway-55/?m=products/videos/html-email-55
and CSS is on
Tim Plumb
Creative Director
Softpress Systems
Follow us on Twitter: http://www.softpress.com/tny/064
Join us on Facebook: http://www.softpress.com/tny/063
Looking for a webhost? We love FatCow: http://www.softpress.com/tny/05v
I think I’ve uploaded it correctly
its at:
www.headline-webdesign.co.uk/email
the images are in the resources folder (i’ve checked via cyberduck)
As you’ll see just no images are viewable
thanks
IAn
Hi Ian,
Take out the .html from the Web Address field, reupload and all should be good. It should look like this:
http://www.headline-webdesign.co.uk/email
its at:
thanks
IAn
Sorry, You’re talking to a bit of an idiot on these things!
remove.html from within the document set up? - it’s not actually there anyway?
Or from somewhere else?
Ian
Sorry, I meant in the Doc Setup dialog. So in the Web Address field in there do you just have the following?
If so then send your document through to our support team and they’ll take a look at it for you:
support(a)softpress.com
Ian
Hi Ian,
Looking at your site I can see that the server is doing some odd things.
If you enter the following URL which should point to a directory
(folder) on the server;
http://www.headline-webdesign.co.uk/email/
you actually end up with an error page;
Not Found
The requested URL /email.html/ was not found on this server.
You can see that the server is looking for a page called email.html
rather than a directory. Check with your web host that you haven’t got
a stray file (typically an htaccess file) on your account that is
causing this.
there anyway?
Tim Plumb
Creative Director
Softpress Systems
This is possibly Apache content negotiation in action. This symptom
likely means that the folder or directory named email doesn’t exist in
the site root of your server. Apache tries to redirect to a whole load
of different URLs when it hits a missing URI, so check with an FTP/
SFTP application and confirm that there is a folder named email in
your site root (alongside your normal index.html that shows your home
page):
/htdocs (or whatever it's called there)
	/email
	index.html
	/Resources
…something like that.
On Oct 5, 2010, at 12:47 PM, Tim Plumb wrote:
Hi Ian,
things.
Not Found
got a stray file (typically an htaccess file) on your account that
is causing this.
there anyway?
Tim Plumb
Creative Director
Softpress Systems
05v
