I’ve placed the initial small piece of code into Page>HTML Markup…>Before and then created a Style named btn and pasted the larger part of code into the Extended part of the style. I have not added any furthur character or paragraph styling. I then applied that style to some text (‘home’ for example) in its own html box. No go. All I see is the generic text and link styling when published.
Hi David
To do this you can put code like this (from the example);
Thank you very much for your reply. Been out all day so sorry not to acknowledge you sooner!
Hmm, right. Definitely need a bit more guidance. My first stumbling block was not quite knowing where to place the generated large chunk of code. I imagined to find tags in Page>HTML Markup… but no so so I added the tags at the beginning and end of the code and used the Page>HTML Markup…Before and popped it there.
Next, took you literally and drew a button using the Button selection from the tool bar, probably not what I needed as it’s not a Form button I need just a link. Continued regardless, right clicked, selected Extended… and pondered whether I should make the attribute in the or
so did both, then put “btn” in the Name and Value.
Clearly this didn’t work so I tried the same by drawing a graphic box and bringing up the Extended dialogue box only to be presented with 4 choices!
Help, please can you guide me assuming my knowledge is somewhat less than you imagined. I am, however keen to delve deeper.
