Can you look at the menu items on the right side of this page under “Artwork” I was wondering if I could get the menu items, people & abstracts, to indent and drop below the submenu, “paintings” instead of going out to the side.
Please let me know if this is possible and what my action settings should be.
Not related to your question, but you might want to know this:
You probably need to rename the page “abtracts.html” into “abstracts.html”
Both Artwork submenu items “paintings” and “abstracts” link to “abtracts.html”
Related to your question:
Why using 2 different horizontally based CSS Menus instead of 1 vertically based one? You have a separate CSS Menu for ‘writing’ and one for ‘artwork’.
Thank you ! I will correct the typo BUT when I publish and check with Safari the links to people and abstracts don’t go to the same page. What browser are you using and how can I correct this?
If I don’t painting to link to anything, should I make it link the current page? I can’t seem to remove it as a link so now it says the link can’t be found.
Yes you can do that or you can make a dummy link by selecting the text you want to link from. Edit>Hyperlink and in the resulting box choose External and type a # in there
