[Pro] CSS drop down menu
Hello
I need a little help on a site I’m working on.
I have a menu bar created using CSS Menu action, the Main menu works fine, but the submenu looks a little strange.
I have a graphic as the menu bar itself, I then have the CSS menu text laying on top of that, now when I hover over the SERVICES word the grey box surrounding
the submenu hits the bottom of my menu bar graphic,
is there a way I can alter the distance from the Main menu and the submenu copy so this doesn’t happen??
Below is a link to the page with the problem.
http://www.piano.co.uk/cssdropdown/
Thank you in advance for you help.
Ian Rose
