Hi all, I have a glitch happening with FW7 which I though was solved but its happened again.
I have already sent email to softpress but its a weekend so I am reaching out here
the css menu is showing thru the images once they are zoomed. I have never seen this happen before and I use exhibeo a lot… http://www.huntslonem.com/testgallery.html
Quickly, there is an style definition in the thumblie-styles1.css file, .xb-thumblie_image-container which has a z-index property with a value
of 110. Change that to 910 (the menu is 900) and all tall images will cover
the menu.
Carla, the way your page is laid out the z-index property cannot affect
anything you can actually draw on the page. The #header div, the #cssmenu-container div, even the #hero-wrapper1 div all have the z-index
applied to no effect.
The Exhibeo slideshow appears in the page code at the same level of the #PageDiv, which has no z-index applied to it – so you could instead add
into your document head (before /head)
This will fix the relative position of the #PageDiv div, which is the
parent element for the header, menu, and thumbs… but not the slideshow
presentation itself.
You can delete those other unnecessary z-indexes you’ve applied.
As for your reply, you are trying to apply the z-index to existing
containers - what I said earlier referred to the Exhibeo stylesheet – to
a class style for an exhibeo-generated item that you can’t see in Freeway’s
work environment. But you can edit the Exhibeo stylesheet.
I also put the z-index 910 directly on the exhibeo item div style
