I have a website and would like to extend my CSS menu with sub menu’s.
I know how I should make this work (list items and increase indent), but for some strange reason I can not get it to work in my site.
I started a new blanco website and started to build the menu all over and immediately it worked like it should. But when I paste the menu back into my real website immediately the drop down function stops working.
The following style is incorrect in your external stylesheet:
#fwNav1:hover > .sub {
visibility:visible;
It should have a space between #fwNav1 and :hover, like so:
#fwNav1 :hover > .sub {
visibility:visible;
How did you create the external stylesheet?
On 23 Nov 2011, at 10:51, DTP2 wrote:
Freeway Pro 5.6.1
I use the Externalize action. After your message I switched it off et voila, it works like a charm now.
Is there another or better way to have one external stylesheet and not having issues like this? Because I would like to keep my html as small and tidy as possible.
