Hi,
Here’s another CSS Menu question:
If you look on the page below, you will see a link that says: Click here to see a Google Map… with the Click here as a link to the Popup window created by the Spawn New Window action. This panel is part of the inline section of the site, but the menus are separate.
http://www.cotswoldengineeringsupplies.co.uk/2010-dev/Contact/howtofindus.php
If you click on the link it should in theory should work, but due to the CSSMenu item on the left hand side any links etc that are underneath the child menu items can’t be accessed! Also if you try to select the copy on the page, you can get so far then the selection changes to the inverse of what you were trying to copy!
The menu items, at the moment, are held in a table, moving them to inline items doesn’t work because you can only access the first 2 or 3 items of the child menus
See here, which is a test that I have just done with the top menus placed in a table:
http://www.cotswoldengineeringsupplies.co.uk/2010-dev/Test_Discount/testmenu.php
As you can see the top menu you can access all the child/submenus, but in the bottom menus you can’t access more than the first few.
I know if I put all the similar colour menus together that would help, but you still wouldn’t be able to access any links below them.
Back to the issue in hand, how can you get all the CSS menu items working and access what is below?
Buy the way the menu items in the table don’t work in Internet Explorer 6 or 7, but they do in IE8…
I’d be interested to hear your thoughts…
Best wishes,
Steve.
