abolinger
(abolinger)
November 23, 2009, 11:18pm
1
I’m using the most current version of Freeway 5
I had a CSS menu set up at the top of each page with a dropdown submenu. Apparently, a setting has changed somewhere and the submenus don’t drop down anymore, though the top level of the menu behaves properly.
Any suggestions on settings to examine?
paulvw1
(paulvw)
November 24, 2009, 12:01am
2
Try first ‘Publish Everything’ by pressing Ctrl first and then go to Publish in the File menu?!
Hope it helps…
abolinger
(abolinger)
November 24, 2009, 12:55am
3
That didn’t do the trick. Any other suggestions?
I tried copying a CSS menu from another freeway site that did work properly. It does not work properly in the file I want it to.
Any ideas?
Can you post a link to your page? Document setup>HTML code:More Readable
abolinger
(abolinger)
November 24, 2009, 1:36am
5
I figured it out. It turns out I added cache-control code before the HTML head on all of my masters. that generated the issue with the CSS menu.
i’m going to figure out how to do cache-control in my .htaccess file and go that route instead.
