[Pro] CSS Menu Pro7
I find that with the Pro 7 CSS Menu (easy to set up) it places a fairly large HTML box on the page which in the first place is a bit of a nuisance when trying to work on the page, but more irritatingly I’m finding that if you place an item in that space with a link, the link doesn’t work. Also if you have a text field in a form that is in the space, it is inactive and you cannot write in it.
First thought is whether I’m doing something wrong or is this just an unfortunate feature I’ll have to put up with.
What attributes have you set for the height of the menu container?
If you haven’t already, try minimum or flexible.
It is always useful for diagnosis to see a live example.
