cecily
(cecily)
November 9, 2011, 4:15pm
1
HI, I’m still pretty new to Freeway 5 pro–I’m starting my third small site with unfortunate time gaps between to forget things.
First time trying to use CSS menus (rather than graphic rollovers) and have a couple of problems.
With horizontal menu for 6 site pages, I can’t get the menu items to space themselves correctly across the page; they are varying widths apart no matter what padding or alignment settings I try.
This horizontal menu will be placed over a horizontal graphic image on the master page. Menu items should be text only on transparent background: no box, no background color. These options are set to “none,” and in page view it looks fine, but in preview or in preview on browser, the whole CSS Menu box has a white background that obscures the graphic it’s on top of.
Any tips?
Thanks very much!–
Cecily
A link to your example online would be useful.
cecily
(cecily)
November 9, 2011, 6:56pm
3
Thanks, Dave–
No host yet, someone else is choosing it. Will post again when I can show the link.
Cecily
Can you not add a page into an existing site - your own for example?
cecily
(cecily)
November 9, 2011, 7:58pm
5
I started to add a page to my site but got nervous that I’d screw up the navigation on that site (ulp) so I quit.
I can show you in a PDF; is there a way I can attach one?
C.
No - a PDF wont help
I wanted to see the underlying code.
You could send a cut down version of the FW file.
Select a page from the site pane at the LHS.
Edit>Copy
Open a new blank FW document
Give it a name etc and save to your Desktop
In the new doc click on the site folder icon in the Site pane and Edit>Paste
In the new doc File>Save Archive
You will get a dialogue box about the current doc being saved prior to saving the archive - click OK
Save the archive and give it a name (again to your DT)
You will now have a folder on your DT containing the cut down FW file with the page you copied out of your site.
Right click the folder and Compress it to create a Zip
Email me the zipped file - address in the People section of FWT
cecily
(cecily)
November 9, 2011, 9:51pm
7
thanks Dave
I saved a zipped archive as you suggest, but so far can’t get to your email from the People list-- will try it again in a bit.
thanks very much
C.
info (at) deltadzine.com
