[Pro] CSS menu
Hi, when i look at the tutorial video of Softpress: Adding Navigation, i see a different CSS menu than the one i got. I have version 2.1.1.0. Where can i get te new version. I am working with Freeway pro (6)
Thanks, Steven
Steve,
are you sure you have 2.1.1.0? On my FreewayPro 6 installation it shows version number 2.1.10 which is higher than 2.1.7. The 2.1.7 is shown on my FreewayPro 5.6.5 installation.
Alain
Alain,
Sorry, you are correct. It’s 2.1.10. Still i miss the option in de link menu to choose current page. I have link, move, click.
Thanks for your help,
Steven
Steven,
I am not sure whether I understand the problem correctly. The link menu on the bottom show all pages as well you can set external links. Normally you would set the links in the master page because this is the only way all links been taken oven automatically to all pages. Check out the short movie here:
Alain
Alain,
What i mean is: when i go to Freeway Actions, CSS menus, main menu settings: there you can choose Links and specifies the color of normal and hover text, and whether links should be undelined or not, There should be an option tot highlight current page. I don’t have this option.
thanks for your help.
Steven
Steven I have that at the top of the action window again 2.1.10
Hi simon,
Thanks, that’s what i was looking for.
Steven
