I can’t seem to get the color changing functions to behave properly for the “Links” menu in my "Navigation Bar. None of the following functions work when published; “Hover”, “Click”, or “Current”. The “underline” function is the only one that works properly. However, I removed that function in the last upload.
I can get the “Background” functions to work when the “hover” is selected, however, that is not the look we are going for. I have played with the colors and different settings to get the “Links” section to work, and cannot get the text to change colors, when being hovered over, clicked on or as the current page.
I have had this same issue with other sites I built. I just don’t understand what I am doing wrong in the setup.
If I am applying the action and setting the parameters within the actions menu, how am I altering the function of the action? The CSS Menu was generated within a Template, in Freeway, I only changed the names.
I think you are giving the text a colour in the inspector; if you double click inside the menu and then go to styles tab in the inspector and double click on .style1 does this style include a colour, if you remove that it should be ok
