I have CSS drop down menus on my web pages, but I cannot work out how get the text in the menus to be in the centre.
The Alignment in the Actions is set to centre, but the text still appear to be to the left.
Select all your text in the CSS menu item and rather than use the alignment in the action use the main Text inspector and set your alignment there.
The one in the action inspector is for aligning the menu items themselves - not the text within.
Hi, Thanks for your reply, the text is set to centre in the Text Inspector, the bullets stay on the left but all the text is in the centre
Yes but that is only on the FW page - when you preview it will look fine.
Hi, I found the solution, when I adjusted the left and Right Padding on the Actions, CSS Menus, the text them centred, thanks for your help
