Here is something I just received because I’m a registered user of WOW Slider. Looks pretty interesting. If one wanted to use this, where would you insert the code into FWP?
Beautiful css menus and buttons with css3 rounded corners, css3 gradient and css3 shadows. NO JavaScript, NO Images, CSS Only! CSS3 Menu. Drop Down CSS Menu.
The menu itself Insert>Markup item then paste the menu code.
Then link in before to the CSS file.
Sounds easy enough. Thanks Dave.
If you use the app then it will generate the necessary resources for you much like the way WowSlider works.
Cool.
Neil1
(Neil)
March 14, 2014, 11:48am
6
I’m a registered WOW user and didn’t get that email, so thanks Raven for posting the link
