I am trying to create a CSS3 menu using Paul’s buttons (CSS3).
I have created the long horizontal button using the purchased action.
Then I have added CSS3 menu action, selecting horizontal view. which worked fine. When I added the page links and previewed the menu - it displays the menu vertically. I was hoping to create a horizontal menu.
Am I asking too much of these actions or am I missing something obvious?
I would be grateful for any help.
Both Actions create their own CSS (though I am unaware for an Action names CSS3 Menu) - it’s very likely that they will create conflicting code that will render incorrectly in a browser.
That is what I thought, although I did spend too much time trying to find an answer that was not there.
Do you think you should use your answer on ‘Freewaytalk’ to help others?
I have used the your “none CSS3” button action with the CSS3 menu layer on top. It looks great in my opinion. However, I feel it would be cleaner just using CSS3.
I have used Walter’s CSS3 corners and shadows together.
In summary, I think your actions are great and well worth the money - I particularly like the “save style” function - which saves a lot of time.
