[Pro] CU3ER
As ever having a mare getting this to work? Anyone out there had any experience embedding CU3ER?
http://creative-website-design-miami.com/test.html
Its created online then you download the files, to upload to the server - the ‘support’ said to try absolute paths but still no luck?
Cheers!
I have never used this but is it possible that you have an ID conflict
ie your containing Div has the ID CU3ER as does your markup
      attributes: {
Or did you put the Markup inside the Div called CU3ER?
When it should be somewhere else?
Not sure what to do to resolve?
I uploaded the instructions here
http://creative-website-design-miami.com/text.html
Seems so easy!
I just changed it to CU3ER to see what happens! I don’t know what to change it too?
I see this??
http://www.progressivered.com/cu3er/support/topic/cu3er-in-freeway-pro-tutorial
No this is created like this? I just added it to the ITEM on the Properties box or it defaults to ITEM1
OK
Well your scripts are not in the HEAD section of your page - are they?
Page>HTML Markup before end Head paste in
<script type="text/javascript" src="http://creative-website-design-miami.com/js/jquery.js"></script>
<script type="text/javascript" src="http://creative-website-design-miami.com/js/swfobject.js"></script>
<script type="text/javascript" src="http://creative-website-design-miami.com/js/jquery.cu3er.js"></script>
  jQuery.noConflict();
  jQuery(document).ready(function($) {
    $("#CU3ER").cu3er({
      vars: {
        width: 650,
        height: 367,
        flash_version : "10.0.0",
        xml_location : 'http://creative-website-design-miami.com/CU3ER-config.xml',
        swf_location: 'http://creative-website-design-miami.com/CU3ER.swf'
      params: {
        wmode: 'transparent'
      attributes: {
</script>
And on your page Insert>Markup Item and paste in
<div id="CU3ER" class="CU3ER">
 <p>If you do not see content of CU3ER slider here try to enable JavaScript and reload the page</p>
</div>
But make sure that the Markup Div is called something other than CU3ER
God I did try that but well I dunno! Working now!
Cheers!!!
J
Works for me
http://www.deltadesign.co/cu3er.html
And me - thanks for the help appreciated
J
