Hi, I have a form setup on a page, with the text labels within form fields. Currently, the user needs to select and delete the text before typing in the required details. Is there anything that can be done to delete the field text when the box is clicked on. ie enabling the user to type the details directly into the form without deleting the text first?
And if you’re concerned about browsers that don’t support placeholder Walter has a js shiv with Prototype and jQuery versions (the latter written by me).
