[Pro] Curvy corners
Just a minor issue, but can someone tell me how to create graphic or html items with curved corners. Can’t find anything in the manual.
Thanks in anticiaption.
In the Inspector, in the Style tab (paintbrush icon) there is an
option to set the corner radius on any element. For graphic boxes,
this is in the Shape segment of the style tab. For HTML boxes, you
need to first specify a Graphic Background and then you will see it in
that segment.
Click on your Graphic item
In the Inspector window and click the 2nd tab (Background)
You will see Background, Border, Effects & Shape. Shape is the one you are looking for.
You will see some simple shapes and a box to enter pixel values in. For shapes with differing corner values use the “Custom” item inside the values menu.
Dale Josephson
Dale Josephson Consulting
Apple Developer & Support
You can also use CSS3 corners for your html items - only and minimal downside is the folks using IE (v8 and lower) will not see the rounded corners, it will degrade to square corners for them.
You can grab the action over at Actions Forge http://actionsforge.com/projects/view/78-css3-goodies
Marcel
Thanks everyone. I’ve got my head round it now. I appreciate all your help.
