[Pro] customer comments on click
I want to show a short customer comment (as html text) and upon clicking a graphic button the comment changes to next one etc. Can’t use moo on page as it is already there - is there a simple solution please.
Where do you have these comments stored at the moment? Have you looked at the Carousel Action for this, or the Sequence Timer and Target Show/Hide Layer? If you already have a Moo-based effect on the page, then you cannot use Carousel (since it uses Prototype.js) but if you’re saying you’re already using Moo on your page, then you can use a different Moo-based effect to switch between visible comments.
Hi Walter.
I just want to expand on the Customer comments here (bottom left of page) as there are now a few more:
Can I ask what you mean when you say a “different Moo-based effect”?
I could just have a link to a new page but prefer to have them contained within the box you see by joining the two existing cells. Thanks
Sorry Guys
At my wits end trying to find a soultion to this.
I’ve been trying html text layers on top of each other and trying to apply sequence click button but can only get 3 of 4 frames to show in sequence and can’t get the first layer to be initially visible and be replaced with next one.
Any help - much appreciated.
Rather than a Moo solution you really need a JQuery one as the Boutique Gallery script you are using is JQuery based.
If you weren’t using that I would suggest this Script/Protaculous based solution from Walter at the top of this page. It might work!
http://www.deltadesign.co/newsticker.html
Hi Dave
Thanks for your reply
Yes it is unfortunate that Walter’s excellent newsticker will not work here.
But there must be a simple solution using show/hide layers (be they html or graphic) with a click through sequence. If i get really stuck I will have to just link to a new page for the comments - but at the moment there are only a few comments and it seems a bit overboard to go this way.
Thanks again for your time.
Trev.
OK - here is something for you to look at - jQuery based
http://www.deltadesign.co/examples/jqueryslideshow.html
Ah - now that looks good.
I had toyed with the idea of something like a 1-2-3-4 - next type of thing - but this looks very sleek. In the meantime on the actual page I’ve used scrolling text/content and up down buttons - here:
http://www.orionoptics.co.uk/ just to get it live BUT I am interested in this. Can you possibly email me or post a link of the freeway example to disect - this would look much better.
Regards
Hi Trev
Out all day but will put an example together for you this evening.
Like your Orion site - really nice. How did you do the revolving pictures?
Kev
Dave
Many Thanks - You are a Star.
Looking forward to example.
Hi Kevin
Thanks for your kind comments.
The Carousel used is a jQuery slider/carousel purchased here:
http://codecanyon.net/item/boutique-carousel/113093
this was then placed into the Freeway document with a lot of help from “Delta Dave” (see this post) who helped me through getting it to work - can’t praise the guy enough I must add - he is a virtual gold mine when it comes to all things “Freeway” and helping out those of us that just muddle through - it works very well as I wanted a bit of movement on the page - but as I don’t know flash and not too hot on the code side of things - this suited fine. There are a couple of versions/examples on there and it is pretty easy to customise via the CSS files.
Thanks again for your post.
Hi Trev
Do you have a link to the thread where Delta Dave helped you with the carousel.
Kev
OK Trev - you can download the FW.5 file from http://www.deltadesign.co/examples/jqueryslideshow.html
Kevin - the thread was http://freewaytalk.net/thread/view/79998#m_79998
But unfortunately it is not going to help you much - a lot of the support for Trev on that one was via email.
If you want to contact me I will send the example file that I sent to Trev - but remember that if you want to use this script it needs to be purchased first.
Hi Dave
That would be great. My email address is email@hidden
Many thanks
Kev
Try again: kevin-at-creativeline-dot-co-dot-uk
