Hi I am looking to customise contact forms, so that that I can make them fit in with the theme of the site. How do I did this?
http://actionsforge.com/actions/view/60-form-element-styler
http://actionsforge.com/actions/view/146-form-element-css
That should do it!
Do you mean style them? not sure what else you might mean actually as generally the page design you would do in the FW so… you have two options of actions for this:
Form Element Styler:
http://www.actionsforge.com/projects/view/39-form-element-styler
Form Element CSS:
http://www.actionsforge.com/projects/view/90-form-element-css
HTH
Beat me to it!
On May 10, 2013, at 11:1 PM, Caleb Grove wrote:
Form Element Styler - ActionsForge
Form Element CSS - ActionsForge
That should do it!
Cheers guys
Make sure you post a link when you’re finished. I’d love to see what you’re up to. ![]()
Thanks for the help guys, this is exactly what I was looking for, I will post a link when the project is finished its an ongoing thing at the moment
