Hi,
How to remove underlines in text between 2 underlined links?
There is LINK1= underlined
and then LINK2= underlined;
Later I wanted to add some text under LINK1, and there I cannot remove the UNDERLINES. I plunged into Styles& Colors, but nothing there to fiddle with.
All text is defined in the BODY tag = default.
I know there is a very simple way to undo underlines, but where?
bw,
Omar K N
Just select the text and choose ‘No Link’ from the link picker at the bottom of the FW window.
If you want to have links that are not underlined then there are several ways of doing that by using the Link styling options in the inspector. There are several recent threads here about that. http://freewaytalk.net/thread/view/98870#m_98870
