Once I figured out the mobile re-direct, I have been working on scaling my pages to work on each popular phone’s size. I have breakpoints set for iPhone 4 portrait and landscape, iPhone 5 p&l, iPhone 6 and 6+ p&l, then iPad mini. That’s actually the easy part, the mobile menu was a little tricky to get to work properly but again FW is pretty straightforward and with the help of this forum & the internet you can figure it out.
My question is… Is there a better way to do this rather than define each breakpoint for devices out there? Are site engineers really looking out for each device size and setting custom breakpoints for each or is there a more flexible way to do this?
Oh okay. I must have understood breakpoints wrong then.
Can you give me an example of what you mean by that though? Before I set breakpoints the page wouldn’t work as expected on mobile devices - in the sense mostly that my menu function was acting goofy. For instance… In portrait my page works great on most devices (since I’ve defined bps for them). If I go into landscape, the page sucks. The menu is mostly what goes haywire. Do you think this is because on my mobile site the menu is set up on the right?
Dave - If you have an iPhone, try accessing my site “www.yuskophotography.com” in landscape. Then you’ll see what I mean.
That was a good read, thanks for that. I will perhaps try to remove breakpoints for each device like he says and come at it the other way which seems far less stressful! Before I tell people my page is mobile ready I have been trying to get it to perform the way I want. In portrait right now it performs the way I want on most common devices, but at the iphone landscape level I’m all messed up still.
About what specifically? The slideshow is too big for my 5S and you appear to be redirecting to an m subdomain.
And yes I do think it is a mistake to have your menu at the right and also it appears you have the hamburger menu set to appear at 1050px. I would reduce that.
Dave - I removed my breakpoints between 320 and the tablet of 768. Is there something I’m missing as to why when you look at the page (www.yuskophotography) on mobile device, it works fine in portrait (on the 5s only) [320 width], but then on a larger 6/6+, or in landscape on the 5 the slideshow is sticking to the right side? I can’t see where I’m able to center that slideshow so that no matter what width the page it is centered. Driving me bananas!
