No matter what I do, the text in the large image is illegible. I’ve scanned it as a high quality tiff and the file looks fine when I look at the .jpg version on my computer but in the Showcase Gallery, it shows up unclear. I have jpg quality set at 100% in the Showcase Gallery setting. PNG is no different. Any ideas would be really appreciated. Thanks.
It’s the Gallerie pp 16-17 image.
http://angelafremont.com/press.html
This looks like a DPS being displayed at less than 1/2 size - it isn’t ever going to be that readable.
If you really want it readable then you are gong to have to use another method to display it.
You could try using the original as a pass-through in Showcase but I am not sure that even that will give you the readability you want and it will certainly produce large file sizes - even bigger than the 0.75Mb you have already.
Pardon my ignorance but is a DPS the same as a PDF? On this side of the pond? Or something else? Thanks for your help.
DPS = Double Page Spread
Reducing the image sizes and using pass through greatly improved things. Thanks for your help.
Maybe but you have huge file sizes - slow to load!
Dimensions 4613 × 3322
File size 1.65MB
You really should clean up your file names to remove spaces and any other strange characters. Files should be named using alphanumerics (A-Z, a-z, 0-9) and underscores _ and - hyphens. Anything else can trip up servers and/or browsers
While this is not done in Showcase the principles of image size reduction are the same
http://www.deltadesign.co/FW6Test/imagetest.html
My large image is 312Kb whereas yours is over 5 x the size at 1.65Mb.
I’ve been resizing everything and got that image down to 565k
I do understand about the names but some things have to stay for now like " and ’ and they’re working so far. I really appreciate your help. It was counterintuitive to me that smaller would be better but it’s true in this case. Thanks so much; big help.
some things have to stay for now like ” and ’
They are precisely the ones that will give you problems!
