[Pro] Double backgrounds
Hi all,
Love the forum here, I’ve been reading for about two weeks as I work my way through my first freeway page. First post so be kind. I’ve seen this question answered here
but the link doesn’t work anymore.
I Like the extra background action and how I can use it in the templates and tutorials but I’m wondering how I can add it into my own page.
However, I might be approaching this problem incorrectly and I’m open to other methods! I’ve got a blog-style page going. I’d like to have a standard background that will adjust with the browser like the normal background function works, but I’d also like another background centred, with a fixed width that will tile vertically as I add new blog posts.
Currently, my workaround goes like this. Use my background image that adjusts with the browser in the “background” menu. Then create a graphic box the entire width of my page (1024px) that I can make bigger as I add more posts. This achieves the result I want but the graphic box can’t tile vertically.
sorry…forgot to add the link.
http://www.freewaytalk.net/thread/view/36943#m_36945
maybe it’s not available anymore.
Try this link: http://www.softpress.com/products/greatfeatures/frameapage/
As to your approach, only browser backgrounds tile. To get the effect of an extended center page section that appears to grow you can use a graphic element only at the top of your page that is a gradient, while a solid color from the middle on down to the bottom of an html box would have a solid color applied that the gradient ends at. Or, you could make a background image for the center section that is much taller than your actual content will ever be.
Thanks so much chuckamuck. I can’t believe I missed it.
It’s definitely a good idea and probably what I’ll end up doing. I’ve been playing with gradients but it’s not the effect I want.
Hi
My name is Martin Bullivant-I just got an email copied to me from you
to someone needing help with framing a page-not sure why… Actually
its very helpful and I’m pleased you did, but did you mean to include
me (or have I inadvertently subscribed to all e-mails on the Freeway
forum… that could be heavy traffic!.
Thanks anyway.
martin
Hi Martin
If you subscribe via email you get all postings to the list as emails.
I set up a rule in my email program and its pretty easy to skim and select
relevant mails - but you can always revert to web only access if that suits
you better.
hope this helps
regards
Brian
Martin Bullivant said recently:
Hi
Thanks anyway.
martin
Hi Brian
Thanks-appreciate the explanation-thank you for taking the trouble.
Martin
On 10 Aug 2009, at 20:02, Brian Steere wrote:
Hi Martin
select
that suits
you better.
hope this helps
regards
Brian
Hi
Thanks anyway.
martin
