I have been asked to help maintain and update a small site for a local club. Two of us share this responsibility. We use Freeway Pro 7 software. Is there a method I can download the current site information, make the needed changes and repost it? If we can do this it would make maintenance of the site much easier.
Thank you - a rookie in Texas
Looks like you’re planning to import HTML into Freeway, right? Can’t be done. Freeway is an HTML generator, not an HTML editor.
Depending on how large the site itself is you could be doing yourself a favor in collecting screen dumps of each page using W3Capture (which creates complete page screenshots), and use them to rebuild the page step by step.
Hi Chuck,
Try putting the Freeway site in your shared Dropbox folder as Thomas suggested. I do this quite a lot when sharing Freeway sites and it works ‘quite well’ although you will find yourself relinking images and other files in the Edit > Resources dialog each time you open a file saved from another machine.
Make sure both Macs are using the same versions of Freeway and the same Actions and fonts and you should be OK.
Thomas, Richard and Tim,
Thank you for your time and effort in responding. I guess this going to be a lot harder then I expected but at least I have a direction to head.
Thank You,
Chuck
I believe Tim Plumb houses FreewaySyle at least partially on DropBox. The downloads on that page are a dropbox link, but I can’t recall if he keeps the native FreeWay files on dropbox. I thought I read something about that once. Perhaps there’s a way.
Hi Doty,
Yes all of the Freeway files over at Freeway Style are hosted on DropBox. They’ve been on various sites over the years (Droplr, Box, etc) but I find DropBox fast and easy to manage.
The files are essentially only there to download. Projects I’ve shared with fellow Freeway users on DropBox are saved in a shared folder so both parties have the ability to open and update the files which, pretty much, works well as long as you don’t want to work on the site at the same time. That would be bad.
Just started trying to do websites in freeway pro…started dozens …finished…none!..all partly good but unable to finish them…can any body point me in the direction of a ’ joined up’ tutorial…the ones on freeways site are certainly not for beginners …isle of wight
