Howdy,
I would like to download an existing website (to include all the files) to another computer (my usual computer is in the shop) so I can work on the files. Is this possible? A quick search found nothing in the support files.
Freeway does not edit the HTML files that it published to your server, so downloading those files would not gain you anything. You need the Freeway document that you saved on your Mac’s hard drive in order to make changes to your site in Freeway. The difference is similar to having a stack of paper you printed out and trying to work from that back to the QuarkXPress document that laid it out.
On Dec 23, 2011, at 4:43 PM, Steve Haslet wrote:
Howdy,
