I am testing out Freeway Pro. I am a iWeb user and I do not want to learn too much HTML crap. I just want to drag and drop photos to my websites (I have several). Photos automatically sizes itself within the box. But with Freeway 5.5, I am unable to do that. When I drag my photo from Showcase, it does not automatically resize. It comes up in its original size. I had a hard time figuring out how to resize it within the box. If I need to resize this for every photo I add to the template, freeway is not good for me. Unless there is a shortcut?
I found by “right click” where it shows options. Odd, there are no options to scale the photo to fix the box. The one I did stretched this lades face left and right, ha. Hmm. Seems some tinkering to do. Guess its a learning curve. Nice to see that I can edit with CS5 or iPhoto. Is there a way to edit photos using Aperture? Thanks for your understanding and support. Paul
Hold down the Option key, then choose File / Open from the main menu. While the Option key is down, the File / Open command allows backup files to be chosen (normally, they appear grayed out in the list of files so you won’t open them by mistake).
On Mar 20, 2012, at 5:11 PM, Paul Rutowski wrote:
I use a Mac. What is Opt+File? I have the option key but what is the file key?
No cigar with this one. I decided to do it all over again. Guess what - Crashed again at the end of the first page. I was using Freeway Express downloaded earlier today on my brand new 27" iMac - OS 10.7.3
No new fonts were added to my new computer. The ones I used on the main page headline was the GIF type with green emboss. Do you think this caused the crashes?
