Does anyone know if you can constrain the angle that a line is drawn to anything other than 45 and 90 degrees by holding down the shift button when drawing a line. I remember in Claris Draw, the angle(s) that the shift key would constrain a line two was changeable in a preference.
I want to constrain the line to 30 degrees.
Thanks, Grayson
