Is anybody else out there experiencing drop shadow problems, mine have gone haywire for no reason apparent???
Have had this issue for quite a few versions of FW Pro.
My drop shadows become a block shadow with no grey tones, completely replacing the enclosing box does the trick but its annoying all the same.
Seems to be no reason for it happening either!
Roger B
Check that the image the drop shadow is attached to is being output with transparency, either as a gif or a png. Jpgs will add a background to the shadow which may or may not match the background of your page.
Hope that helps. Regards
Derek
Just a though and maybe not relevent, are the images ‘pass-through’?
Nathan Garner
FW5 Pro | MacBook Pro | Snow Leopard
Derek
None of these guys, I had all the usual problems early on in my FWP career.
These are nonsensical. I was creating a slideshow and copy pasted three boxes all with the correct settings but different shadows.
I also created three separate boxes not in a slideshow and they are all different shadows???
Regards
Steve
Nathan Garner
http://www.austinwellsdesign.co.uk
Derek
See my reply to Tony’s Formatting problem http://freewaytalk.net/thread/view/80335
The same solution might work for you.
