Is there an action or code that will let me add a drop shadow to a CSS menu?
Do you mean like this?
http://www.deltadesign.co/fw_examples/menutest.html
Awesome! Is there anyway to control the amount of shadow, so that it’s a little lighter, say 40% vs 75%?
Dave,
I figured it out, but I’m having problems with the drop down on Recent Projects. What do you think is wrong?
http://idealynx.com/clients/cs/
Kelly
Hi Dave, any thoughts on the problem I’m having above?
Have a look at the width for the CSS Menu settings - Main and Sub Menu
Is the Sub Menu width smaller than the main one?
If so try making them the same.
I have “Use Content Width” checked for the Main menus and 10 pixels set for the submenus. I take it I need to set a specific width, correct?
Also what is EMS and should I be using that?
An Em is a relative unit of measurement with one Em being equivalent to the supposed default text size in the Browser of 16px
But it can get more complicated than that - stick to what you know.
Good idea. So, I need to set an actual Main and Submenu width to make the drop shadows work, correct?
I was able to adjust the Sub-Menu size to 1 Em larger than it was and that worked. I think the only reason I was using Ems is because that’s the default with some of the built-in templates.
