I’m enjoying using EasiForm and everything is working fine, but I receive the resulting e-mail, the subject name always includes the word “on” and I’d like to remove that. In other words, if the subject name is Hunter-Jumper, it looks like this in the resulting e-mail:
TBH I think the quickest way to solve this is for you to send me the
Freeway site file (Just the site file, nothing else) and I can take a
look for you.
mail:
Unfortunately I won’t be able to see the problem from the web page, I
need you to send me the * actual * Freeway * site file * for the site,
no other files or folders needed.
On Feb 12, 2011, at 11:01 PM, Peter DeArmond wrote:
If you place the easiForm Error action in a cell above the text
‘Name:’ rather than below it then the text the Error action outputs
would look better there rather than right below the text ‘Name:’.
Also selecting the same cell the Error acgtion is applied to and then
selecting a text style that works with the other text on the form will
style the text the action outputs to match.
HTH
