Hi,
I made some very simple rollovers…
They turn to blue boxes when you rollover the navigation items.
Is there a way when the person rollsover the change to blue box is not so sudden and quick- almost like a nicer slight fade? I have seen this many times but not sure how to do.
In other words, when you mouse over the rollover does not smack you in the face but comes in a little easier.
You can see them here…
http://www.hoffkids.com/hoffkidsonlinema.html
Thanks in advance,
Barry
Sounds like you need JS for this one.
It’s not related, but I created a multi image rollover a while back that had a corporate logo on a nice background. I created a spotlight in PS and moved it across horizontally, doing multiple saves as I went. I stacked the images and created several empty objects as set them edge-to-edge so that when you move the mouse it makes the spotlight seem to move across the logo. Cheap thrills (and for a JS hound, much easier than this caveman method), but it was a cool effect.
thanks for sharing the idea!
