[Pro] Editing code?
How do I edit Freeway Pro HTML code?
Do I need a separate HTML editor and if so, which one should I get that’s MAc compatible?
Why do you want to edit FW’s code?
FW gives you several ways to add code to your FW doc - that is all you should need.
Editing code in an external app is a one way process, furthermore FW will overwrite those edits the next time you publish the page.
