[Pro] Eliminate Form Building Headaches
Just had to post this…I love Freeway but building forms and getting the scripts to work or using the php actions with the ioncube loader is always a hassle from one hosting company to the next (I am a web designer with many clients). The other day I found Web Form Builder by Coffee Cup Software. If your forms are simply pass throughs, this little program is super! It creates the php files, uploads them to your server and gives you the html to paste in your page. In Freeway, just choose insert html item, paste the mark up and you are done! And the forms work!!! Every time!! And, you can make transparent forms and place them over anything on your existing pages. Awesome!! Check it out if you hate building forms!
Personally I use Tim’s excellent PHP Feedback Form action FreewayActions.com | PHP feedback form
Once you have created one form (in a table structure with the action applied) it can be copy/pasted to many sites and yes - it just works.
Unless, that is, you are hosted by GoDaddy.
Always nice to have another tool option. As another option I use Forms To Go also. http://bebosoft.com/products/formstogo/overview
