Sounds pretty straightforward. Thanks for posting the instructions. One question though. How do you see the fonts in Freeway?
Do you have to add them to the Font Set built into Freeway Pro (Edit/Fonts Sets…)?
I have tags like h1.header, h1.tagline, p.homepa…
Can I just say that you should only use 1 h1 per page - doesn’t matter whether you call it h1.header, or h1.tagline its still an h1.
Also that h1 should be followed by a para of relevant text.
cheers Dave.
Raven, you can set up to use the typefaces locally. See this help topic Using web fonts when developing locally
Dave, would mind elaborating on your comment?
See this vid as well More than one H1 on a page: good or bad? - YouTube.
I will just change my headings logically, h1, h2 h3, with p for the accompanying text
Simply put - there should only be one h1 Tag per page as it signifies the most important content. Logic says that there is only 1 “most important” section.
Your h1 should also contain the most important keywords describing the content on that page.
So to put an h1 tag on the company name on your page is a waste unless you only do it on your index page.
