Hi, I’m a new dummy on the block learning Pro 5 so please bear with me.
Firstly, I have always looked to Freeway Talk for help and found it…so hats off to you all and many thanks.
I need to embed an image on the page so all is in the html code to upload without the resource available. Can’t seem to find an answer immediately - so thought I would ask.
Could you explain a little more what you mean by this? Do you mean that the image should be embedded within the HTML so that there doesn’t need to be a Resources folder or an external file to show the image? If you could explain what your use-case is here, I might be able to help.
You are right. The image should be embedded within the HTML so that there doesn’t need to be a Resources folder or an external file to show the image?
I am working co-jointly with someone else using a different programme and want to upload revised but same size pages onto their host without the image as a resource.
If the image is really small, you can use a data src to hold the image. How large is this image?
On Nov 23, 2011, at 3:20 PM, kasbah wrote:
Thanks Walter,
