I have suddenly started to get this error -5000 which stops me from saving my work…the error indicates i do not have enough privileges to complete the task
I have raised a support request but thought that someone in the community maybe able to help
What version of Mac OS X are you on, and is this a document you were recently working on, or one that has been lying fallow for a while?
I have been working on this document every day for a while. I am on Mountain Lion and have been since it was released.
Something else rather odd is that i have tried to create an Archive and that brings up a whole raft of errors caused by missing links to resources, when i try to relocate the missing image, which i find FW will not accept that the link has been updated.
An update… i have a backup system, just in case my main work unit gives trouble, the Files on the backup were up-to date. Running FW on that system which is only at 10.7 showed that when i Edit resources all the links were perfectly OK, I could save etc with no problems. Resync’d that system with the main work system and now FW is behaving itself again…But rather troubling… not sure what i would have done without the backup system.
Lion introduced this system where files could acquire a “lock” just by sitting around for a period of time without any changes. Is it possible that some of the files in your Resources folder (published by Freeway) were unchanged for a while, and then suddenly Freeway needed to change them? If it tried to update (remove and replace) a locked file, I wonder what the dialog would say.
System Preferences / Time Machine / Options – Lock documents [duration] after last edit. I have this preference unchecked, as it seems clearer to me that way.
The permissions error is due to an incompatibility between the way Freeway saves documents and Time Machine on 10.7+. We’ve found the problem and fixed it internally and hope to have a fix available soon. For a bit more information on the problem, take a look at this KnowledgeBase article:
Thank you for your response, my concern is that i ran FW Pro with Lion and had no hint of an issue then, it has only appeared after running with Mountain Lion for about 7 - 10 days… was i just lucky not to see the problem under Lion? or is this a new issue?
I had this problem on a few Freeway documents after upgrading to Mountain Lion. Repairing permissions fixed it. However I unplugged my Time Machine disk and haven’t backed up in a few days…doing that now…while Freeway is closed and not running.
