Hi Philip,
Some of the buy now links work and others do not which leads me to believe that there are illegal characters in the product descriptions. It looks like you’ve copied and pasted the descriptions into the Action palette as I can see ‘%0A’ in the link code which is an encoded carriage return. This is causing the hash validation checker on the Mals site to get upset and is rejecting the link by throwing the error.
Really the Action should clean the input to make sure these illegal characters don’t get through but for the moment if you clean out the product descriptions and make sure you don’t have any hidden characters in there you should be set.
Hi Philip,
Both the Softpress Freeway Shop Actions and my own Mals E-Commerse Suite Actions (http://d.pr/bWSN) support product variations with the latter supporting more variations. Looking at the code of your page it looks like you are using the Freeway Shop Actions. You can find the PDF manual for them here where you need to look up ‘E-Product Variation’; http://d.pr/fkLV
On 2 Oct 2013, at 01:02, Philip Rochester wrote:
Thank you very much for the help guys, I very much appreciate it.
Additionally, what’s the best way to add product variations? I.e. Different sizes which I have in stock for ordering.
