Peter2
(Peter)
December 11, 2009, 7:51pm
1
Hi I keep getting this error message when I try and buy something off my site. Does anyone know which web site address I should put in there and where do I change my details on the admin page, I can’t seem to find your details as stated on the error message.
cheers
Pete
FREEWAY CONFIG
The shopping cart will automatically attempt to load a new configuration file when you change your settings in Freeway.
Sorry, it was not possible to load your new configuration: It was not possible to connect to your webserver at:
http://ww4.aitsafe.com
Please login to Admin and correct the URL in Your details
Well in one of mine it is simply
ww11.aitsafe.com
None of the http stuff
Sorry I realise that is not very clear - I mean in the Action Palette
Also check in your cart setup on Mal’s server
Peter2
(Peter)
December 14, 2009, 9:59pm
4
Hi David,
tried everything but still no luck. Will keep going.
Pete
Peter2
(Peter)
December 15, 2009, 12:26pm
5
do you have to upload your site before you can connect to mals e-commerce?
I’m trying to view in safari preview and I keep getting the error message even though i think everything is set correctly on freeway and mals
cheers
Pete
Well if you think that one of the settings in Mals is for your web address then it certainly would be worth trying.
I didn’t realise that you hadn’t uploaded! I think that you have to be online to load the initial config file.
But also check that you have set the web address of your shop in Document Setup
Also see page 12 of the Freeway Shop User Guide
