Suddenly I get this error on my site wen try to upload?
Help appreciated!
Erik
Auto Clear Fix
tag has no properties
sio.graphicid.nl
Help appreciated!
Erik
Auto Clear Fix
sio.graphicid.nl
Erik,
What version of the action are you use, and with which version of Freeway? Also, have you tried opening the action in the actions palette and clearing the error?
fw7.01
Clearfix 0.2
Yes cleared the error, keeps comming back
Close Freeway, still the same
For Freeway 7, you’re going to need version 1.0.2 of the action. Get it here: http://actionsforge.com/actions/view/299-auto-clearfix
Keep in mind that the updated version is only compatible with FW 7 - if you need to use 6, you are going to have to reinstall the older version.
The version for 7 has just been updated so there’s no longer any conflict. Download it here:
http://actionsforge.com/actions/auto-clearfix http://actionsforge.com/actions/auto-clearfix
