[Pro] Esperanto Display Problem (Not the Comments!!)
Just built this for ourselves - it’s fine on a pc but on an iPhone, it appears as just a thin strip down the left hand side of the page.
Any idea what I’ve done wrong?
Thanks.
http://thosemediachaps.com/redspot5/
This is caused by the vimeo video:
https://dl.dropboxusercontent.com/u/8231701/screeners/ios-simulator.jpg
But there should be help underway:
http://actionsforge.com/actions/responsive-video
(Thanks Tim for this - haven’t tried it yet, but will do for sure).
It was doing that before I added the video - also the menu bar disappears when viewed on iPhone :frowning:
Honestly, the only chance I have is to debug this in Xcode (have no real mobile device). But everything looks fine there by just deleting the video. Menu bar is visible (and working) as well (with or without video).
https://dl.dropboxusercontent.com/u/8231701/screeners/iOS-Simulator-2.jpg
So sorry if I can’t be of further help.
Thanks Thomas - you’re a star! I’ve just used the responsive vid action as per your suggestion and it seems to work fine now!
Small typo
she can worth with a minimal team or can…
