[Pro] Exhibeo not uploading
I can’t seem to get the Exhibeo slide show to upload on the front page of this site. There are four other Bloxx pages that uploaded just fine. I am using Filezilla to upload and try as I might I can get it to work. It previews on my system just fine. Any Ideas. Thanks for the collective group help.
http://segerstrombasketball.com/
Mark,
It appears that the Exhibeo Export files aren’t on the server, or at least are not at the right location.
How are you adding the gallery to the page, though a HTML item, or using the Exhibeo Import action?
I’ve been using the Exhibeo import action. Would putting it into an HTML item be better?
I just created an new file upload and am uploading it with Filezilla.
Thanks, Caleb, for taking a look.
Mark,
I would recommend using the Freeway action.
It’s quite odd that Exhibeo isn’t working correctly, as all the other galleries on that site work perfectly. It appears that, for some reason, Freeway isn’t publishing the needed files for that particular gallery.
I only have one suggestion from here, besides contacting Softpress, and that is to do a “clean” upload. Wipe everything from Freeway off of your web server, and do the same for the local folder that you are uploading to first. Then, upload to that folder from Freeway, and upload everything to your web-server using Filezilla (or better yet, Freeway’s own FTP option).
If that doesn’t work, contact Softpress support and they should get you straightened out.
The most likely explanation is that you are missing some files from your manual upload.
I would definitely agree that you should at least try FW’s own upload facility to see if that resolves the problem. FW manages file names on the fly and you may not realise that some files have been renamed and so miss them out.
You say it does work locally so that would suggest the manual upload is at fault.
“The most likely explanation is that you are missing some files from your manual upload.” That’s what I think as well. I tried a clean file copy and no luck. I attempting to use the Freeway upload. This site is photos heavy and I have not had success in the past with the Freeway upload. It wants to upload much of the site and then stall. There are 21000 items to upload. I’ll keep you posted as things develop. Thanks again for taking a look and giving your advice.
All is good. The FW upload added the needed files. The slideshow is up and functioning.
Thanks for you help.
