[Pro] Exhibio Appearance
Hello Panel. These days when I open Exhibio on my iMac, the bottom controls are off the bottom of the screen. They reappear if I use the green fullscreen button, but I would really like the smaller version with the controls visible. Any ideas?
Paul
Exhibeo mailing list
is it possible you changed your screen resolution recently and that is causing it? I checked and the default Exhibeo screen can be resized from all 4 corners with OSX 10.9.5
Hi PaulM.
I have OS 10.10.5, and a recent update to this may have caused the problem.
Paul
