[Pro] expanded graphic
Could anyone please help me on this basic question?
I have a page with a background supersizer, and i want to insert a small png bar in the middle of the page, that accompanying the page no matter the expanded size of the browser.
I’ve draw an html box set to expand: overflow hidden, etc.
When I try to insert a graphic box inside this html to put the png color, the html box expands prefectly but the graphic box remains fixed left or right…
I believe must be a very simple answer but i can’t find it.
Thank you very much for your help
jose barreiros
If it’s a solid color, instead of inserting the graphic box, why not just apply the color to the html box?
because I want a transparency…
Use the CSS3 rgba background action to set both color and transparency of
your html box.
http://actionsforge.com/actions/view/236-css3-rgba-backgrounds
thanks Ernie!
your html box.
CSS3 RGBa Backgrounds - ActionsForge
Or, without an Action, specify a solid graphic background, and set the transparency there. In the Inspector, second tab, Graphic Effects, click on the square solid icon.
your html box.
Thank you Walter, I’ll try that
you all are very kind!
your html box.
