Hi,
Can I create something similar in FW.
See site “Facebook button/icon” on the right. Hover and emerge.
Thanks, Lode
Hi,
Thanks, Lode
Try this;
http://www.freewayactions.com/test/facebook-slideout-panel/
Something I created for a project that never got started.
Experienced Freeway designer for hire - http://www.freewayactions.com
Hi Tim,
Thanks, I must do something wrong, the animation works, but the FC window stays blank. I fill in the FC adres:
see project, this is just a testsite:
http://www.roselnet.com
Blue icon.
What is the difference CSS/jQuery
FW 7
Regards, Lode
The Facebook ID is just dierendorp, not the full URL.
They are quite different technologies but in this example achieve the same results. If you want to support older browsers that don’t support CSS animations then use jQuery although they should run on pretty much any browser created in the last five years.
Dierenartsenpraktijk Dierendorp | Bonheiden
http://www.roselnet.comBlue icon.
FW 7
Hi Time,
A moment of “brain failure”, or the opposite. It wants the real ID and not the www address. Exactly what I wanted!
Thanks for this action.
(I have some more question, but I try to solve them first)
Bye, Lode
Hi, our messages crossed, and it works with “dierendorp” to, amazing! I like when things are simple.
Thanks for the info.
bye, Lode
Hi Tim,
Just a quick question; is it possible to use this action to show other things than a FC page? An image perhaps?
Thanks, Lode
At the moment the Action only does this one thing. If you want to use the sliding panel to reveal other content then send me an email and I’ll see if I can extend it to allow you to do this easily;
http://www.freewayactions.com/product.php?id=con
