[Pro] fading images
Hi all, could anyone tell me the best way to achieve the following:
an initial picture on page load which fades into another, then another and then back to the first to repeat over and over again.
I realise this could be done with an animated gif, but the picture quality is quite important in this case.
Many thanks in advance
Try the sequence timer action.
If you place all your required images in position on your page as layers - one above another and apply the Target Show/Hide Layer action to each image - making sure each has a different Target # (this can be changed in the actions pallet).
Then apply the Sequence Timer action to the page and select each Trigger.
Give it a go and see if my instructions make sense.
Or, if you are using the lates version of FW, you can use the Showcase Gallery/Slideshow action.
Nathan Garner
http://www.austinwellsdesign.co.uk
FW5 Pro | MacBook Pro | Snow Leopard
Many thanks Nathan, I’ll give that a go this pm.
Sequence Timer - ActionsForge
Trigger.
Nathan Garner
Hi Nathan (and anyone else who’s looking at this). Thanks, your
suggestion basically worked but I have a couple of problems with it
and don’t know how to fix them.
If you go to: http://www.trevreav.co.uk/STTEST you’ll see that image 1
is up there for a split second, then fades and returns, any idea why
it disappears?
And between Rollover 1 and Rollover 2, the initial first image
reappears, I would somehow like them just to play in sequence without
image 1 appearing between the second 2 images.
But it’s getting there!
Trigger.
Nathan Garner
Trev,
Select each one of your images and goto your actions pallet and try these settings:
Initially : Hidden
Restore : Sticky
Effect : Fade
Nathan Garner
On 20 Dec 2010, at 13:21, Trevor Reaveley wrote:
Hi Nathan (and anyone else who’s looking at this). Thanks, your suggestion basically worked but I have a couple of problems with it and don’t know how to fix them.
If you go to: http://www.trevreav.co.uk/STTEST you’ll see that image 1 is up there for a split second, then fades and returns, any idea why it disappears?
And between Rollover 1 and Rollover 2, the initial first image reappears, I would somehow like them just to play in sequence without image 1 appearing between the second 2 images.
Nathan Garner
Perfect!!
Many, many thanks. I always get confused with toggle, sticky etc.
On 20 Dec 2010, at 13:34, Nathan Garner wrote:
Trev,
these settings:
Initially : Hidden
Restore : Sticky
Effect : Fade
Nathan Garner
