using favicon action and favicon is being loaded but it doesn’t show up in my browser.
any advice?
cheers
Peter
any advice?
cheers
Peter
Is this true in all browsers, or just Safari?
Safari has (maybe had, I think they worked on this problem a few
versions back) a problem with caching these icons (or the lack of an
icon) very stubbornly, and it becomes difficult to see any changes
once it has done so.
Try looking in Firefox, and see if it’s there. Or post a link and the
wisdom of the crowd will surge forth!
up in my browser.any advice?
cheers
Peter
thanks for the advise. appears in firefox. apple should sort out the safari problem.
cheers
Peter
Try Safari / Empty Cache from the main menu, and see if that does the
trick.
safari problem.cheers
Peter
Or go into [your home folder]/Library/Safari/icons and delete the
offender.
Peter
