Robert3
(Robert)
February 11, 2012, 3:10am
#1
I am able to use FeedBurner’s BuzzBoost feature working and embed my blog posts onto my site. ( http://support.google.com/feedburner/bin/answer.py?hl=en&answer=78976&topic=13240&ctx=topic )
But I would like to edit the CSS like the instructions say and that’s where I get totally lost
If you can tell me where in Freeway Pro to put these code snippets I would appreciated it. http://support.google.com/feedburner/bin/answer.py?hl=en&answer=78974
~Rob
Robert3
(Robert)
February 11, 2012, 6:29pm
#2
Alright, basically I am having a hard time figuring out where to put this CSS information:
div.feedburnerFeedBlock ul {
margin-left:0;
padding-left:0;
list-style-type: none
I tried selecting an HTML blobk and adding a new style to it, than I clicked on Extended to add custom styling. I put “div.feedburnerFeedBlock ul” in the name part and the rest of the code “{
margin-left:0;
padding-left:0;
}” in the value part.
I saved that style but nothing changed
Robert3
(Robert)
February 11, 2012, 6:30pm
#3
If anyone has any idea how to edit CSS information please let me know.
Omar_K_N1
(Omar K N)
February 11, 2012, 7:13pm
#4
Let me try an answer:
You select the item, then you go to the menu: Item > extended,
Try this / my pence.
/ Omar
::: Communication to improve civilisation :::
s_ip
Code snippets like these should be added in Page>HTML Markup in the before End Head section
They will need to be wrapped in some style tags so the raw CSS is
margin-left:0;
padding-left:0;
Which then becomes
<style type="text/css">
margin-left:0;
padding-left:0;
</style>
That is choosing the first example on the page you linked to.
Robert3
(Robert)
February 12, 2012, 2:06am
#6
Yay!!! It’s starting to do something. Yes putting it in the HTML Markup is working.
Thank you so much.
~Rob
