Does anyone know why the newest FireFox won’t display the JW flash player. Earlier versions displayed it fine, but not the latest 2 or 3.
Post a link to a page where you have a problem.
Hi David, there are several…
http://www.douglascalcott.co.uk/NewLifeToday.html
http://www.colinowen.com/light.html
These pages work fine in all other browsers (I don’t have I.E)
Thanks for looking.
Colin.
All work fine with FF 3.6, IE 7/8 and Chrome on a PC running XP. IE takes ages to load but then thats why its cr… .
Have you tried emptying your cache ?
s
Hi S, Thanks for that. I did try the usual things, but no joy. Perhaps it’s a Mac thing…
Colin.
It could be 64 bit mode. Safari 5 won’t display the players either, but you can start it up in 32 bit mode and it works fine. I read on the Adobe site that flash doesn’t run in 64 bit. Maybe Fire Fox is 64 bit…
Colin.
All working fine for me using Firefox 3.6 and 4b2.
You don’t have any Flash blocking extensions installed on your browser do you?
Colin.
HI Joe, No. Are you on Mac? I’ve heard that it’s working on Windows systems. Actually, Safari 5 is looking good. Seems quicker than all the other browsers I’ve got…
Well, I just tried FF 3.6.8 on my non intel G5 and it works fine. So, is this a Snow Leopard thing, or is my iMac playing up?
I am on a Mac, yes.
Hi Joe, are you running Snow Leopard?
Yep.
Then it is my iMac. That’s OK. So long as the players are being seen out there, that’s all I was worried about.
Cheers,
Colin.
Hi Colin,
I know you said you don’t have one installed but try going to Tools>Add-ons in Firefox and disabling everything then refreshing your pages. I’ve seen extensions preventing things from working so many times before.
Cheers,
Colin.
Hi Joe, it’s a fresh install with no addons. I did check just in case there was something from a previous version but found nothing. Just had a look at the error pages and the player is greyed out…
Cheers,
Colin.
